C
crater
A week or so a ago I email Digital One regarding the uptake of the new AAC+HE audio standard which is being adopted in some countries over the next couple of years. AAC+ offers significantly better quality than MPEG Layer II. Here is the reply I got....
"Thank you for your query.
1. At present there are no plans for any radio station to use any other audio standard than MPEG Layer II in the UK. Ofcom has specifically restricted all DAB broadcasting in the UK to MPEG Layer II, including the new multiplex licences.
2. Other countries may introduce AAC+HE coding, in some cases alongside MPEG Layer II, but this will be locally determined.
3. If AAC+HE begins to achieve significant take-up in other countries then at some point we might expect to see some AAC+HE compatible radios on sale in the UK but only in products from manufacturers which are truly pan-European. It is worth pointing out that consumer electronics products are often country-specific versions - UK products have 13amp plugs for example. Manufacturers tend not to add unnecessary cost to products if there is no local market for it.
4. Radios which can receive AAC+HE are expected to be backwards compatible i.e.: they will also receive radio stations broadcast using MPEG Layer II. On that basis, even if radios that use AAC+HE are sold in the UK, they will also receive MPEG Layer II stations.
5. If in the future Ofcom allowed AAC+HE to be used in the UK, there is likely to be a further period of perhaps 5-8 years before a significant number of broadcasters offered new AAC+HE services. However, we would expect many stations, particularly the more popular ones, to continue to be available for some time beyond this in MPEG Layer II.
Kind regards
Hannah Larkin
Digital One
Kind regards
Hannah Larkin
Digital One
