No Impact ! (yamaha set up problem)
Discussion in 'AV Receivers & Amplifiers' started by dUnKle, Feb 10, 2005.
Tags:
  1. dUnKle
    dUnKle
    Jan 1, 2001
    13,708
    +1,496
    Hi :hiya:
    Have a Yamaha 2400 and a Denon 1910 DVD player - speakers consist of
    603s as left and right - cc6 as centre - rel quake and rel 100e
    when watching TV or playing games having the amp on -15 is plenty loud enough and its impossible to hear anyone else in room talking
    however,
    when watching DVD the impact is just not there
    even at -10 I can hear the keys being pressed as I type this and watch the matrix :( :eek:
    There seems to be very little loudness and impact
    any ideas why ?
    amp was self calibrated using the mic - and using spl speakers are at 75db - bass sent to both front and subs - with fronts set as large and the speaker level connections also used
  2. John
    John
    Dec 13, 2002
    11,010
    +2,688
    Do you have to calibrate the DVD input seperatley ?
    JS
  3. dUnKle
    dUnKle
    Jan 1, 2001
    13,708
    +1,496
    MMMMMmmmmmmmm
    not sure
    will try hunt out the manual
    but dont think so
  4. dUnKle
    dUnKle
    Jan 1, 2001
    13,708
    +1,496
    well could not find anything
    seems i am missing something
  5. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Duncan, I remember you posted a while ago regarding DRC, well some DVD players also have a Dynamic Range Control which cuts down on frequencies for late night viewing. Usually 3 settings best switched off so you get full on sound from all frequencies. Maybe thats a possibility?
    Matt
  6. Diamond
    Diamond
    Put more volume? The amp won't break, the different sources just are out of balance.
  7. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    1910 has Dynamic Compression, try that??
    Quoting Diamond
    "Put more volume? The amp won't break, the different sources just are out of balance."
    Surely -10 on amp should be blowing your nuts off :eek: mine on -20 nearly shakes the house down and gets me evicted!!
  8. Diamond
    Diamond
    Yes it could, it depends on the amp, speakers and the room at least. If I think sound is too low on db's, I simply put more.
    PC, TV, dvd/cd all are different on levels, it even depends on the disc. Db's on the screen don't mean anything unless they are calibrated and proven right.
    Night mode is one possibility.
  9. dUnKle
    dUnKle
    Jan 1, 2001
    13,708
    +1,496
    have turned dc off
    is that correct ?
  10. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Yessirrrree
    Matt
  11. dUnKle
    dUnKle
    Jan 1, 2001
    13,708
    +1,496
    well in that case no difference - its strange
  12. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    When you calibrate the amp with the YPAO have you changed the equilizer setting? If you havent change it to FRONT and then re-run it. It should make the sound much better overall.. Also try taking the speakers ot mall and the bass out to the sub alone. I found that was the best way for me. Also check the 2400 hasnt got the dynamic range compression turned on. Finally use a SPL meter if you have one to check the setup and remeasure the speaker distances as the YPao is only so good :eek:
    Hope this helps.
  13. dUnKle
    dUnKle
    Jan 1, 2001
    13,708
    +1,496
    will try
    whee is DRC on the 2400 ?
  14. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    On the 1400 its under Manual setup:sound
    Have you also checked the volume control on the dvd player?
    I would suggest reading both manuals a couple of more times to see if theres something you have done by accident thats compressing the sound.
    I would happily offer to take the 2400 of your hands and have a look myself :D :rotfl: :eek:
  15. dUnKle
    dUnKle
    Jan 1, 2001
    13,708
    +1,496
    well I will continue to play about with it
    have fronts set as large as I have the Rel 100 connected via speaker connections to reinforce the front speakers
    all drc was turned off
    just a little confused that its stil MUCH louder for Tv than it is for DVD
  16. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    From the DVD to the amp I assume you are using co-axial or optical. Apart from Dynamic range control nothing should effect the level of volume.
    Have you tried the analogue connections from the 1910 to the amp? See if they are louder then the digital connection.
  17. Rickyj @ Kalibrate
    Rickyj @ Kalibrate
    Well-known Member AVForums Sponsor
    Jan 29, 2003
    5,720
    Surrey
    +1,749
    You haven't switched on the midnight mode on the receiver have you?
    Ricky
