no image with XBox Official MS High Definition AV Pack
Discussion in 'Xbox Forums' started by nonikandola, Sep 17, 2005.
  1. nonikandola
    nonikandola
    i have a modded xbox that allows me to change my pal xbox to a ntsc xbox.
    i understand that to have high def u need a hd lead, and a ntsc xbox.
    i know this because i was hapily running my xbox via the component lead of the high def kit.
    but after re-arranging some furniture the xbox wont show an image on my tv via the hd cable. but will via my standard cable.
    i have tried switching between pal and ntsc with enigma, but still no luck, any ideas.
    i have the standard XBox Official MS High Definition AV Pack, and a pioneer 435fdh plasma.
    has anyone known the XBox Official MS High Definition AV Pack to fail.
    i am getting desperate as i am used to a high res xbox.
  2. nonikandola
    nonikandola
    forgot to say thanks in advanced
    (look at the time of the post, ive been up this late trying to sort the problem, thats how desperate i am)
  3. Pooon
    Pooon
    Dec 26, 2002
    7,118
    Canterbury, Kent
    +722
    not heard of a HD-box fail yet. can you get a image if you just use a normal scart? if so can you disable the HD options(720,1080) and then connect the HD pack again so see if the hd box is still working in any way
  4. buzlightyear
    buzlightyear
    Oct 8, 2002
    945
    46
    London
    +116
    i know this sounds silly but you have got all the wires connected up to the Pioneer right. Blue and green do look alike when your head is stuck down the back of a cabinet.
  5. nonikandola
    nonikandola
    when the normal scart is in the hd options arnt shown.
  6. nonikandola
    nonikandola
    yeah there all right and the input on my tv is swet to comonent
    any more ideas
  7. nonikandola
    nonikandola
    can anyone help me??????????
