no image via comonent on NTSC box
Discussion in 'Xbox Forums' started by nonikandola, Sep 23, 2005.
  1. nonikandola
    nonikandola
    Hi Fells
    I really need your help.
    One day I decided to clean behind my TV. This meant disconnecting all my av equipment and as a result my Xbox wouldn’t show an image via the component leads. ( as supplied by the officail xbox hd kit)
    So I tried with the standard lead and that worked fine.
    I then tried switching between pal and NTSC but the component still didn’t work.
    I then phoned pioneer (the display manufacture) who sent out an engineer and confirm the TV connections are ok.
    I then luckily managed to get friends Xbox hooked up and that worked fine via all the cables I have including the component. So that rules out the cables being faulty.
    I then changed all my settings in evox to mach the working Xbox but still no luck.
    Any ideas?
    Thanks in advance
  2. nonikandola
    nonikandola
    there must be someone who can help me
  3. nonikandola
    nonikandola
    i dont know if this will help at all but i have managed to get a hold of an rgb cable for the xbox. when plugged in it only shows an image in red (ie games dash and media centre etc)
  4. nonikandola
    nonikandola
  5. nonikandola
    nonikandola
    beliveable, no one knows, wow
  6. SillySausage
    SillySausage
    Jul 10, 2004
    596
    Leicester
    +14
    Hi, did you ever sort this out?
    I have just bought a Yamaha 575 amp, connected my modded XBox to it via component, and nothing....
    Can't find any help with it at all. Doh
