No headphone socket - help!
S
SiegeA
I am a total noob here so this may be a totally dull question but...........
I recently purchased a Sony DAVF200 but discovered it has no dedicated headphone socket.
Does anyone have any ideas how i can connect headphones to this system please?
The link shows a picture the available connections:
http://www.trustedreviews.com/home-c...nema-System/p1
Thanks in advance!
the mechanic
Hi there,
I was going to suggest using a dedicated headphone amp, something like this LINK
but seeing as your system does not have any phono outputs (looking at the review you linked to) it wouldn't work.
However, you should be able to use some bluetooth headphones as the Sony has bluetooth connectivity. Take a looksee HERE and see what fits your budget ?
Hope this helps ??
Graham.
pandemic
You probably need a 3.5mm Female Audio to RCA Male Cable. Might be difficult to find though. It's easy to find a 3.5mm Male Audio to RCA Male Cable, but then you also need a 3.5mm female to 3.5mm female socket
