Timjrea
So here's the issue. I have a TV that I hook up in my backyard occasionally and have installed a box with an HDMI Port on it for ease of hooking the TV up. That box has a wire that connects inside it and runs through the wall to a closet in my house where it attaches to a 4 way HDMI splitter which in turn is connected to a cable box. The problem I'm having is I'm not getting a signal to the outdoor tv. The other two that I have connected to it work fine. The outdoor tv has worked fine for months and now all of a sudden just keeps coming up no signal.
I have troubleshooted it a bit and this is what I have determined. Connected the wire that goes through the wall straight to my cable box still yeilds no signal however if I connect the wire straight to my Roku I get a signal. At the same time if I connect it to the Roku through the splitter I get no signal. Now I would believe it was the splitter but then the wire should work when connected directly to the cable box yet it doesn't. Could it possibly be an issue with the splitter, cable box, wore combo.
I'm at a bit of a loss and how to fix it. Any help would be greatly appreciated.
Replacing the HDMI in the wall is not really possible.
