I have a Yamaha receiver which has no HDMI inputs but does have 2 component video in & 1 out plus 2 optical audio and 1 co-ax audio connections.
This is what I want to connect to it:
I currently have a HDMI switch with the HDMI from the Blu-ray and Humax connected to the switch inputs and the HDMI output from the switch to the TV HDMI input. Audio is just connected by optical from the TV to the receiver.
This seems to give a reasonable surround sound from all sources but I can't help thinking it could be better as I'm not sure whether having all audio go through the TV's optical output gives the best sound.
I'm considering getting a HDMI to optical/co-ax/audio converter to split the audio from the HDMI.
This would have the HDMI connected the same as the existing switch but the audio would be separated with each source connected directly to the converter. This would also reduce cable runs.
My questions about this are:
1 x HD PVR with 1 HDMI out & 1 optical audio out.
1 x Blu-ray player with 1 HDMI out & 1 co-ax audio out.
1 x HD TV with 2 HDMI & 1 component video inputs and 1 optical audio out.
- Do they actually work?
- Are they like HDMI cables where cheap ones are just as good as dear ones? I've seen prices from under £20 to over £200 for what looks like the same thing!
- As audio bypasses the TV will this produce any discernible difference to the sound?
