No FreeSat signal
Discussion in 'Satellite TV, Sky TV & FreeSat' started by lonewaller, Sep 8, 2005.
  1. lonewaller
    lonewaller
    I have not been receiving a FreeSat signal from Sky since Tuesday evening, but the EPG seems to be working fine. Ironically, my signal quality seems to be around 50%, up from its normal 20%.
    I have not added anything new, nor was I mucking about with cables or system setups.
    Anyone know if there's a problem with the FreeSat signal or have I a problem with my digibox (Amstrad DRX400)?
    Brian
  2. Heinz
    Heinz
    Aug 4, 2005
    408
    Earle Colne, Colchester
    +15
    The latter appears most likely (20% signal quality is very low though).
  3. lonewaller
    lonewaller
    Ok, so it turns out that, following a phone call to them, I merely had to re-boot the system.
    However, it raises an interest point. While I wasn't receiving the FreeSat channels I had a signal strength of c80% and signal quality if c50%.
    Now I've got my channels back, the signal has gone back to its normal strength of c90% and quality of c20%.
    Anyone with any ideas as to what's happening here?
    Brian
