Quantcast
No Edit button for Contacts
hazelwoods
I've tried to delete a couple of numbers from Contacts on my iPhone 4.
I open Contacts, choose the entry I want to remove and up comes the INFO page. But there is no Edit button at the top right hand side, and nothing when I scroll down.
I rebooted the iphone, but nothing appeared.
I checked iTunes for an update, but software is up to date.
I'm confused :(
wright8
I'm confused :(
close the app from the multi bar. double tap home button and then keep ur finger on the contact app and click the X. try reopen and fingers crossed
gkpm
If it still doesn't work after the above, check where are you syncing your contacts with.
See under Settings > Mail, Contacts, Calendars and see which account shows Contacts enabled.
