No Dvi Output though Connected
Discussion in 'Projectors, Screens & Video Processors' started by rik, Jul 10, 2002.
  1. rik
    rik
    I have bought a Samsung 191T LCD monitor which is great but I have a problem that I hope you can help with. It has both a VGA and DVI connector, both of which I have connected to the relevent sockets on my GF3 Ti500 (blue one and a white one, 2 wires from monitor to card) I have installed the drivers for the monitor and the latest version of Detonator 29.? but I cannot for the life of me get the card to output down the DVI channel. On the NVida graphic setup auto detect monitor always chooses analog and when I force it onto DVI the screen goes blank like theres no input signal. The monitor has a light to show which signal it is getting and always the analog is lit
  2. GearHead
    GearHead
    Perhaps VGA has priority over DVI, either on the card or in the monitor. You only need to have one output connected. Try starting up your PC with only the DVI cable connected.
    Allan
  3. rik
    rik
    I have the same answer to another post in the techie forum. Think you both might be right, will try it out.
    Thanks for your reply
