no DV in
Discussion in 'Blu-ray & DVD Players & Recorders' started by davyuk, Nov 6, 2004.
  1. davyuk
    davyuk
    Hi all
    I am undecided in which hdd/dvd recorder to buy -it's between the panny 85 and the tosh 32. I would prefer the panny just because it's a panny but it doesn't have DV in. Does this really matter - can I still connect my Digicam without dv in and if so what exacly is the loss of quality if any?
    Many thanks in advance
    Davy.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,599
    You can connect Digital Camcorders with S-Video - but it won't be as good as a DV connection. If you want to use a digital camcorder I would suggest going for the Toshiba or push the budget and go for the Panasonic E95.
  3. davyuk
    davyuk
    Cheers mate
