no DTS in Pitch black
Discussion in 'Movie Forum' started by Yaka, Jul 22, 2001.
  1. Yaka
    Yaka
    Dec 20, 2000
    1,798
    2
    63
    +142
    i cant seem to select DTS from menu or while movie is playing ,its the R1 unrated edition
    my amp is yammy A5 an pioneer dv-05 ,my other dvds work fine with dts bar this one
  2. Ian Cox
    Ian Cox
    I have also got this version from the States and I have had no problems with it. I have also got a Yammy amp and a Pioneer DVD player
    In the languages menu (I think thats right) you should be able to select DTS.
    Are you not able select it from here or is it that you can select it but the amp does not register that the DVD is playing a DTS track?
  3. kmb
    kmb
    Jul 1, 2001
    This version has both DD 5.1 & DTS 5.1,as
    mentioned before,go to languages from the main menu,this will bring up separate spoken
    languages list.Select DTS (2nd choice down)
    and this will bring up an explanation screen
    about DTS and equipment needed to decode it.Select Yes to continue and this will start
    the film with the less annoying DTS intro.If
    there is still no sound then perhaps your amp
    is failing to auto detect the DTS signal.Have
    tried selecting DTS manually on your amp?
  4. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    ... I may be talking out of my RCE here but wasnt Pitch Black R1 one of those films that was released in different versions ie DD5.1 or DTS Cut or Uncut etc ?
    Have you definately got a DTS one ?
    Sorry if I have wasted your time ... Paul
  5. Guest
    Bit odd. Worked fine for me. I have the same version. I think you do need to select it when the film is playing.
    I'll have a go tonight.
  6. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    has this dvd (r1 UNCUT) english subtitles?
  7. FoxyMulder
    FoxyMulder
    Pretty sure this is one of those films where you can switch the audio between DTS or Dolby or indeed the commentaries track whilst the film plays using the audio button on ur dvd remote.
  8. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,342
    +853
    Just to point out that the R1 unrated DVD is in DD EX and is better than the DTS track IMO.
  9. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    no one?
  10. FoxyMulder
    FoxyMulder
    I compared the 2 sound formats and its pretty close, but i still prefer DTS, not much difference on this particular film but i thought the surrounds were more active and better defined and the bass was more aggressive which i love.
  11. PASMASTER
    PASMASTER
    yes its got english and french subtitles . top film :smashin:
  12. Moray M
    Moray M
    Nov 20, 2003
    84
    Bucks
    Riddick gets another outing in "The Chronicles of Riddick", which is, I believe, due for release in the not to distant. :)
  13. FoxyMulder
    FoxyMulder
  14. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,342
    +853
    I've watched this film many times and compared the two tracks many times!
    I prefer the DD EX track, decoded as DD EX!
    If you have not got EX decoding then go for the DTS version (which isn't in DTS ES)!
  15. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,031
    U.K.
    +645
    I have the same R1 unrated edition.
    DTS works fine (go into languages i think)
