No Dolby Digital sound from Pearl Harbour
Discussion in 'AV Receivers & Amplifiers' started by ianchown, Jan 24, 2004.
  1. ianchown
    ianchown
    I have a DENON AVR 1802 Surround Receiver. I cannot get Dolby Digital sound the Pearl Harbor DVD although I can from any other DVD???? Any ideas???
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    Does Pearl Harbor have a standard Dolby Digtal 2.0 mix by any chance as well as DD and/or DTS? Have you manually selected DD in the audio set up before playing the film?
  3. bobbypunk
    bobbypunk
    that is a problem i've heard before, same film same receiver, i'd ring denon and ask if they know??
  4. krusty
    krusty
    i can help you. the 1802 has a chipset fault ,denon will pick your amp up and correct it. just contact them. other movies that wont play include jp3. also this problem also affects some kenwood amps and onkyo models that were built at the same time. its something to do with ex flagging. i was very pleased with denon because they only had my amp for 1 week and it cost me nothing to send it as they arranged it all.
