No Dolby Atmos
Discussion in 'AV Receivers & Amplifiers' started by leejenuk, Feb 15, 2018.
  1. leejenuk
    leejenuk
    Jun 2, 2005
    94
    11
    Can anyone please help, I recently upgraded my bu ray player to a SONY UHD player and am running it through a Onkyo TX- NR646 Atmos amp, for some reason I am not getting The blue Dolby atmos light come on when playing Bladerunner 2049 and also Game of thrones Dolby Atmos!! Both were set for Atmos on the films menu, I get the Atmos light when playing a film on sky and I had no problem with my other blu Ray player.
    Am I missing something?
  2. dante01
    dante01
    Mar 5, 2009
    46,432
    +11,176
    What format is indicated as being received by the AV receiver? Have you ensured to set the player so that it bitstreams audio via HDMI? I believe that the HDMI audio output on Sony players should be set to AUTO in order to achieve this. Also ensure that SECONDARY AUDIO is turned off on the player.
    THe other thing to check is that you are not applying NEURAL:X upmixing to the incoming signal. If you do then you'd end up with just TrueHD plus Neural:X instead of Atmos.
  3. leejenuk
    leejenuk
    Jun 2, 2005
    94
    11
    The settings for audio on the player are
    Digital audio output AUTO
    DSD output OFF
    BD Audio mix setting ON
    DTS Neo OFFDSEE HX OFF
    Audio DRC AUTO
    Downmix STEREO
    Does this look right?
  4. leejenuk
    leejenuk
    Jun 2, 2005
    94
    11
    Also the symbols on the amp are
    PCM AND THE DOLBY SYMBOL
  5. dante01
    dante01
    Mar 5, 2009
    46,432
    +11,176
    Set BD AUDIO MIX to OFF and the same for the DOWNMIX setting if this option is available.
    Your issue is with the player's configuration and the signal it is outputting to your receiver.
  6. leejenuk
    leejenuk
    Jun 2, 2005
    94
    11
    Brilliant Dante01 that seems to of fixed the problem, thank you.
