I turn my pc on, fans whirl, lights come on, the mouse and keyboard light up, I can turn on/off NUM lock, caps etc but I get no display on my monitor. Fans on my graphics card whirl etc.
I've tried dvi and dp cables in every port, when I connect or remove the cables from my ports, the TV detects that I've connected/removed the cable and the screen displays the no signal message and states it's going to go into sleep mode every time I connect or remove the cable but I can't get a signal.
I don't have another pc I can test the graphics card in (I'm assuming a GPU issue) nor do I have access to another gpu to try (although I'm trying to get one cheap)
I have a Windows 10 pc with a Radeon HD 7950 (I think)
What do people suggest? Any ideas? I've removed all my components and cleaned them with compressed air and reseated everything, nothing works.
Is it a case of trying to source another gpu or?
