No digital out problem...
Discussion in 'Desktop & Laptop Computers Forum' started by Rob, Dec 20, 2001.
  1. Rob
    Rob
    Jul 17, 2000
    1,286
    Norwich
    +35
    OK , finally got the picture looking great, only now I cant seem to get DD or DTS output from the souncard (sounblaster 5.1). I've tried everything I know, Digital out only in sounblaster settings, AC3 disabled (tried enabled, no difference) and power DVD output is set to 6 channel. When I run the speaker test, only front L/R are working. Lead is plugged into the SP/DIF out (yellow connector). Don't know what else to do :(
    Any help muchly apprecieated.
    Rob.
  2. Desmo
    Desmo
    Jan 4, 2001
    14,453
    Braintree, Essex.
    +6,498
    You wouldn't be running Win2k by any chance would you?
    If so, it's a known problem with Win2k and the SB Live. Install service pack 2 and it should cure the problem.
  3. Rob
    Rob
    Jul 17, 2000
    1,286
    Norwich
    +35
    Desmo,
    I'm running Windows 98. Is it still worth installing service pack 2, does this apply to win 98?
    Thanks Rob.
  4. Desmo
    Desmo
    Jan 4, 2001
    14,453
    Braintree, Essex.
    +6,498
    No, the service packs don't apply to Win98.
    You said PowerDVD is set to 6 channel output. It should be selected as using SPDIF.
    Not sure what else to try after that.
  5. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    Rob,
    Have you selected 4 speakers, in the Sound Blaster speaker set up.
    Ken
  6. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,329
    Berks, England
    +152
    Rob,
    I don't know if your 5.1 has similar connectors the Soundblaster Live Player? I was surprised to find the yellow "digital output" is actually a stereo 3.5mm jack socket.
    I have taken a simple 3.5mm to twin phono stereo connection to two digital coax inputs on my amp (OK, so it's not 75ohm and shielded, but it works ok for me for now).
    Through the one connector (left?) I get PC digital sound (windows sounds and MP3 from WinAmp), plus pass-thru Dolby Digital and DTS streams from WinDVD 3.
    Through the other I do not get any PC sound, but still get the WinDVD pass-thru.
    As these are two different digital signals in this one 3.5mm jack socket, I suspect using a mono 3.5mm jack plug will short them together and the digital signal will be lost. Perhaps that is the problem with your 5.1?
    cheers,
    Rob.
  7. Desmo
    Desmo
    Jan 4, 2001
    14,453
    Braintree, Essex.
    +6,498
    Good thinking Batman, but no cigar.
    I use a mono jack and get SPDIF out no probs at all.
    It passes a PCM signal for CD/Winamp and also passes a DD/DTS bitstream through PowerDVD.
  8. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The correct adapter to use is a mono RCA - mini jack connector.
    Jeff
  9. NickBull
    NickBull
    I use a mono RCA connector from Maplin, cost me all of 98pence.
    I don't think the problem is the connector. I have ATI player and WINDVD and get DD and DTS pass thru fine using WinDVD, but with the ATI player I only get PCM stereo.
    This doesn't really answer the question, but it does mean that it looks like some DVD players have problems with DD pass thru.
    You could try downloading WinDVD trial version from Intervideo I beleive. It's fully functional but only lets you play 5 mins of any disk. If this works then it may be a matter to be refered to Power DVD people.
    cheers
    Nick
  10. Rob
    Rob
    Jul 17, 2000
    1,286
    Norwich
    +35
    I'm also using the mono jack converter from Maplins, so no problems there. I'll try some suggestions and see how it goes. I guess these things are never simple!
    Thanks for all your help.
  11. meva
    meva
    Feb 20, 2001
    354
    cornwall,uk
    +14
    Rob, did you manage to get this sorted? I am outputting a digital signal to my av amp but can only get prologic sound ????? no dolby digital bitstream, help! thanks.
  12. Guest
    Same here (see my seperate post), no DD or DTS with the SB Live (1024 or 5.1), it's driving me nuts!!! Ordered an M-Audio 96/24 anyway which hopefully will sort it all out...
    Andy
  13. meva
    meva
    Feb 20, 2001
    354
    cornwall,uk
    +14
    When I installed the card there was a seperate connector for a digital bitstream which I didn't connect as I didn't have a cable. I read somewhere that you don't need to connect this ??? Is this my problem ??? I'm getting a digital output from my computer to my a.v amp ( I have no analog connection now ).But I'm getting no dolby digital bitstream for my amp to decode:confused:
  14. meva
    meva
    Feb 20, 2001
    354
    cornwall,uk
    +14
    EUREKA !!!! Sorted, Creative's confusing interface got me there. Thought I had disabled the sb live's ac3 decoding but I hadn't:clown: All working now:D
  15. Rob
    Rob
    Jul 17, 2000
    1,286
    Norwich
    +35
    I eventually got it sorted by buying another soundcard. I had 2 faulty soundblaster cards, but bought another brand (can't remember the name) and it worked first time. The shop that sold me the cards tested them so I know is wasn't me! A few people have made the mistake of not disabling the onboard AC-3 decoding. An easy mistake.
    Regards Rob.
