"No Dial Tone"
Discussion in 'Desktop & Laptop Computers Forum' started by pantages, May 16, 2005.
  1. pantages
    pantages
    Jan 7, 2004
    945
    2
    Boston
    +60
    Using W98 and Wanadoo broadband with Speedtouch ADL connection modem.
    Unless I connect to ISP within a few seconds of completion of booting up, I cannot connect! I get a message saying 'No Dial tone' - even if there is one. Has anyone any advice please?
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    I've got a Speedtouch connecting to Tesco ISP without a problem but I'm using XP Pro. What are yout connection settings ?
    Richie.
  3. pantages
    pantages
    Jan 7, 2004
    945
    2
    Boston
    +60
    They are as originally installed with the CD. That is, nothing is checked except 'Always Dial My Default Connection'. I have only one email account.
  4. MikeFish
    MikeFish
    For broadband shouldn't you have it on 'never dial a connection' or 'dial whenever a network connection is not available'?
    If you check 'always dial my default connection' it will try & dial using your dial up modem instead of your broadband modem, which is why you are getting the 'no dial tone' message.
  5. pantages
    pantages
    Jan 7, 2004
    945
    2
    Boston
    +60
    Hmmmm. I had the setting on 'never dial a connection' but since I tried 'always dial my default connection', I have been able to connect at any time! My narrow band modem is disconnected anyway and I have only the one ISP. Reading the Wanadoo setup instructions differs from the Speedtouch instructions, so I am really not sure what the ideal settings are.
  6. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    Stupid question, but are you using the phone cable that came with the modem or the old one that was part of your old modem ?
  7. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Yep, with Broadband there is no 'dialling'. It should be a username/password handshake. The only qustion should be do you connect as soon as you boot up or do you connect only when using e-mail or a web browser.
  8. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    I'm not so sure Cable Monkey, if you only have one connection then you need to activate that connection whether it be Dial Up or Broadband. If you select 'Never Dial', when you open IE/Mozilla, you will get an empty page and you have to connect through the Start Bar.
    There might be a service or program that starts just after boot up that is stopping you from connecting. Try disabling everything you have on start up, also see if you have any conflicts.
    failing that, try removing Wannado and re installing.
    Richie.
  9. pantages
    pantages
    Jan 7, 2004
    945
    2
    Boston
    +60
    No 'No Dial Tone' as yet after reinstalling. I'll post again if it does it.
  10. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    Another stupid question... you don't have a voicemail service which changes the dial tone when you have an unplayed message? This always catches me out when trying to dial into work...
  11. pantages
    pantages
    Jan 7, 2004
    945
    2
    Boston
    +60
    Yes, I do, (the continuous tone), but it is so seldom used and has never been in use when the 'No Dial Tone' message has appeared. There seems to be no pattern which I can identify as a cause. It has happened once today, but when I started up later, I waited some ten minutes before activating Speedtouch and all was well. Please don't stop asking your questions, they are anything but stupid and chances are you may hit the hail on the head! It is more of a nuisance than anything because rebooting seems to take an age and, in any case, it shouldn't be happening. I emailed Speedtouch but they only advised me to reinstall the modem and check that my start up menu was not responsible in any way.
  12. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    Don't know W98 so forgive errors, but look under "My network places" > "view network connections" are there any dial up accounts enabled? If so right click and disable.
  13. pantages
    pantages
    Jan 7, 2004
    945
    2
    Boston
    +60
    Thanks, but it is a solo account, no others enabled.
