No Colour on Plasma when playing dvd
Discussion in 'Plasma TVs Forum' started by paul55, Jan 18, 2004.
  1. paul55
    paul55
    Got a Fujitsu Plasma P42HHA10ES which has a scart socket only
    and a Sony Davs550 DvD player which has a S-video and yellow video phono socket
    when i connect using the yellow phono video out from dvd to the TV scart socket the picture comes in colour
    when I connect using s-video from the the dvd player to scart on TV it only comes in b/w
    tried using differnt s-video to scart leads but all give me b.w picture
    any idea's? or am i stuck with video out rca to scart .
    and is the picture any clearer using any other methods cause
    to tell you the truth im not that impressed at the moment.
    One other ? It says you can control this tv by pc using the rs232 cable to adjust settings
    do i need additional software to do this ? is so where do i get it from ? on the net ?
  2. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,415
    63
    Andover
    +158
    OK, so you've composite (yellow) and S-Video.
    Not sure on DVD player, but on mine you have to select how you want to output the screen i.e. composite, s-video, scart etc. is there any such setting on your dvd player?
    Also on the plasma check the settings on the scart socket (on screen menus?) - i don't *think* it should be set to RGB, if it is try another setting.
  3. PhillipStanton
    PhillipStanton
    Are you double, positively sure that you've got an S-Video to Scart cable and not a Scart to S-Video? The pin connections are different and you would end up with a bw picture if you used the wrong one.
    I only mention this because I've done it :D
  4. paul55
    paul55
    definatly sure its s-video to scart got a diagram on the lead package to show direction of signal
  5. mxs
    mxs
    Nov 28, 2003
    236
    Lowestoft
    +9
    You will need to select svideo in the AV menu on your TV.
  6. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    That's assuming, of course, that the SCART on the Plasma is S-Video capable.
  7. paul55
    paul55
    that's the thing not sure it is ?
    and i aint got a remote for the thing !
