No colour in Component output - any ideas ?
Discussion in 'Plasma TVs Forum' started by tetrarch, Sep 15, 2005.
  1. tetrarch
    tetrarch
    Jan 20, 2005
    60
    I have my Panny TH42PWD7 connected up by component cable to my DVD Recorder DMRES20 but all the output is in black and white, whether DVD or TV signal there is no colour at all. Viewing the same output by RGB is fine.
    Any ideas ? - I really hope it's not the cable as this has been connected up post-decoration !!!
    Regards
    Tet
  2. Piers
    Piers
    Dec 11, 2002
    1,985
    Cheshire
    +228
    Check signal type is set to component on the plasma and output is set to component on the DVD recorder. If both are I fear the cable.
  3. xx396
    xx396
    Jan 3, 2005
    168
    I got this when the cables weren't quite in properly but it also did something amiss with my Panasonic DMREH50 until you switch from RGB to S-Video with component from the video settings menu.
  4. tetrarch
    tetrarch
    Jan 20, 2005
    60
    Precisely the problem - thanks very much - Phew !!!
    Regards
    Tet
