No coax cable input on my Panasonic 7UY
Discussion in 'Panasonic TVs Forum' started by ytee, Jul 19, 2005.
  1. ytee
    ytee
    Mar 31, 2005
    7
    This may seem like a lame question to many of you, but is there a way I can hook up the coaxial cable from my cable box to my Panasonic plasma, (7UY)? It doesn't have a coax input. I'm using the component cable output for another TV.
    Thanx
  2. mike7
    mike7
    Jan 3, 2005
    4,804
    Norwich
    +569
    I think I am right in saying that the 7UY is a display monitor, in other words it does not have any tuners on board so you cannot feed it with a conventional co-ax aerial cable. The specs I have seen do not have Scart sockets either. I know that the specification of panels vary from one country to another so yours might be different.
  3. stevelup
    stevelup
    Aug 13, 2002
    6,407
    Swindon
    +1,037
    It would be an outrage to feed it with RF anyway if you have digital cable.
    Your best bet would be to get a component video splitter so you can run both devices that way.
    Regards,
    Steve
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Beat me to it steve, the splitter is the way to go. You can use the RF if you use a TV tuner of some sort, a VCR perhaps. I reckon the splitter is the cheap way as well as the right way.
