No Chapters. Am I Doing Something Wrong?
Twin Turbo
Established Member
Hi guys.
I recently purchased the Panny DMR-EH80V, and love it! :thumbsup:
I've copied a lot of stuff from my Sky+ HDD onto the 80's HDD (in XP mode), and did all necessary editing and chapter creating.
I have two similar programs that I wanted to put onto a single 4.7 DVD-R. They're total running time is 2 hrs 13mins. To allow for this, I set the Flexible Record to 2hrs 14mins, and started transferring from HDD to DVD.
That was this morning before I left for work. Just checked the finished DVD at lunch, and both programs fit onto the disc! :clap:
The problem is, none of the chapters I'd setup transferred across. Did I do something wrong? It wouldn't be the first time if I did!! :rolleyes: ;)
HMHB
Outstanding Member
The problem is that you've re-encoded at a different rate and so it won't keep your existing chapters - you'll probably find it's put some auto chapters in every 10 minutes or so. The chapters are only kept if you do the high speed dubbing from HDD to DVD.
Twin Turbo
Established Member
Thanks John.
But, correct me if I'm wrong, if I use the high speed recording, I won't be able to fit both programs onto the disc, will I?
LV426
Administrator
Staff member
Probably not. The trick is, to select the correct recording mode (aka compression rate) that will be required for the finished product before recording onto the HDD. Then you can edit, chapter, whatever, while on the HDD and high speed copy to DVD when done. The high speed copy does not re-encode; just transfers data over, so there's no recompression and hence no degradation.
A
ABP
Seems like you will have to copy to RAM with FR then copy back to HDD then add the chapters you want and then put the chaptered version From the HDD to the DVD-R/RW as you wanted!
What a Faf!!!!!!!!
AB-P
Twin Turbo
Established Member
What a Faf!!!!!!!!
AB-P
What a stones!!!! :mad:
So, from now on, whenever I want to transfer something from my Sky+ HDD, I'll have to set the FR to the length of the program, transfer it to the 80's HDD, do my editing, and then high-speed dub to DVD?
Shouldn't be too much of a bother, 'cause everything I'll be putting onto the HDD will come from the Sky+ HDD anyway!
As an aside, I'd like to thanks everyone for this site. It's great that people like me no longer have to be afraid of technology! :clap:
Keep up the good work guys!!
necronom
It's not just me then! I've just spent ages setting up titles, chapters, thumbnails, etc on two programs ("Spider-man" and "The Spider-man Story"). Everything is perfect (all chapters at correct GOP positions), and as I was about to start the Rate Conversion Dub on my Toshiba XS34, I read the notes at the end of the chapter saying that chapters are not copied! :mad:
I'll now have to do a Rate Conversion to another file on the HDD, then set up all the chapters again, then high speed dub to DVD.
I'm not happy :(
Couldn't it have mentioned this on page 1 before I set up all the chapters...
HMHB
Outstanding Member
I think it's something we all learn about after the first mistake ;)
RAB67
Established Member
Not quite - you can record to the HDD in FR
A
ABP
RAB67,
If you download from Sky+ a few different programmes to edit with a play list you will have to split and re record every title individually.
... or am i missing something?
necronom
At least on your XS34 you can change the recording bit rate and re record directly from the HDD to HDD and then add the chapters etc
I Miss my XS34... you don't know what you have until it's gone!
AB-P
HMHB
Outstanding Member
I normally decide on SP when transferring a load of stuff from Sky+ and just copy the whole batch in SP mode and then split them into 2 hour (or less) chunks. I've found that SP is good enough quality and so don't bother working out the space required for FR.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
