no blower for heater peugeot 806 help
academical63
hi no blow for my heater peugeot 806 doesnt seem to be live feed it is electrics its not the fan itself as put a live feed and it was turning i dont have fuse layout does anybody know what the number is for fan in fuse box its a 1996 model anybody help its not easy when its raining and u need demister please help thank you bye for now
car-man
Quite a common fault on Peugeot.
Could be the ignition switch (the electrical block behind where the key fits), try waggling the key and see if it comes on.
Check the live feed from the ignition switch to the blower or the resistor module.Put a live direct to the motor from the switch.
Check the connections on the motor itself, they sometimes burn out.
FunkyMonkey
Many years ago I had a 1996 Peugeot 406. A lovely car.
The same thing happened to me.
Just above the passenger footwell there was some carpeting that went up to jsut below the glove box. That's where some wiring had come loose that was causing my blower to stop. Garage fixed for me for next to nothing.
Try checking wiring. :)
