No BBC One HD via Virgin Media?
Discussion in 'Cable TV & Virgin Media TV' started by dante01, Jan 8, 2012.
  1. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    I've been unable to get BBC One HD for the best part of today via my TiVo. I was wondering if I was alone in this or if others were also lacking the channel?
    The "There is a problem with the signal for this channel …" message appears when I try to get the channel. All other channels, HD and SD all seem to be okay.
  2. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    I've resolved the issue.
    I put the TiVo in standby then turned off the power. I turned the power back on and waited until the bright red LED dispersed before coming out of standby. I waited until after the wait screen and then pressed TV (not Home) when prompted.
    BBC One HD is now back to normal.
  3. christam
    christam
    Jun 28, 2007
    1,787
    Bournemouth
    +281
    I've had this happen 2 or 3 times and used more or less the same fix - my standard practice is always to turn off the power and/or reboot when there are similar issues with this type of hardware :)
  4. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    It seems to have something to do with the TiVo not responding to the VM servers. The restart must kick it into sending a return signal to the servers and start the two conversing with one another again. Strange how it only affected one channel though?
  5. Lancia34
    Lancia34
    Jan 4, 2005
    9,756
    +3,112
    Same problem here this evening but with quite a few channels. Also some recordings didn't work so am rebooting it now to see if it works.
  6. Lancia34
    Lancia34
    Jan 4, 2005
    9,756
    +3,112
    Reboot fixed it :smashin:
