So I think I just blew/broke one of my Cerwin Vega XLS 215's.
The problem is that there is absolutely no sound or vibrations from the 15" elements at all. I have replaced the fuse, and checked the voice coil for burning damage, and there seems to be none. I will test the nonworking speaker versus my working speaker with an Ohm meter, as soon as I get my hand on one, but meanwhile I was hoping to get some advice/answers on what might be the problem. I have checked my CXA-10 amp too, and there were no blown fuses as far as I could see. I'm no expert, so I might have missed something. I suspect that the problem lies somwhere in the speaker, because when I change the output channels on the amp, it's still the same problem with the same speaker. Does anyone have any idea whats going on?
EDIT: I just did the 9v battery test. On the speaker that plays fine, there was a pop and the elements moved. On the speaker that does not work properly, there was one pop, then nothing. No movement at all. When I changed the polarity, there was another pop, but no movement. When switched the polarity again, the result was the same.
EDIT2: So I tried moving one element from the speaker that's good, into the bad one, and there is still no sound at all from the subs. Does anybody know what might be causing this? Is it the amp after all?
