No Audio from all Blu-ray, some Blu-Ray 3D and some Ultra HD 4K discs
Discussion in 'Digital TV & Video Players & Recorders' started by CRAddison, Jun 18, 2018.
  1. CRAddison
    CRAddison
    Jun 17, 2018
    3
    Stafford
    I have a strange issue with my set up where certain discs will not play audio during films through my Sound system (they work fine for others and in the menus play fine on all).
    My set up is as follows:
    • Sony KD-55XD9305 TV
    • Panasonic DMP-UB700 Ultra-HD 4K Blu-ray Player
    • Sony RT3 Soundbar and Speakers
    I also have a Panasonic DMR-BWT700EB Blu-ray and HDD recorder plugged in.
    The 4K Player is connected via HDMI from the Audio+Video Out to HDMI2 on the TV.
    The Soundbar is connected from HDMI1 (ARC) on the TV to the HDMI input.
    The HDD recorder is connected to HDMI3 on the TV.
    I have tried numerous HDMI cables and the latest ones are all HDMI 2.0b/HDCP 2.2 with support for 4K @ 60Hz 4096 x 2160p HDR UHD 4:4:4 18Gbps.
    Most of my 4K Blu-rays work fine including The Martian, Sicario, Passengers, Saving Private Ryan* etc. However there are some that just won't play audio through the Soundbar: Dunkirk, The Accountant, Unforgiven, Despicable Me 3?
    I've found from what I can tell that all standard Blu-ray discs also fail to play sound through the soundbar.
    Blu-ray 3D discs seem hit and miss - for example Puss In Boots 3D works fine, while The Lion King and Jurassic Park 3D don't.
    DVDs work fine (as you'd expect).
    I can always drop back to the TV sound (although it defeats the point of having a sound system), and when I play Blu-rays through my other player (HDD recorder) the sound works (although there is often an annoying lag).
    * Interestingly I had problems getting Saving Private Ryan 4K to work - it came up with a message saying that I needed 4k equipment to play it. This prompted me to replace the cables (again) and after much fiddling (I discovered the Enhanced Mode for HDMI on the TV which was disabled by default - and enabled it on all ports) it eventually just worked. Next time I put the disc in though the same message came up. After more fiddling, during which the 4K player did a firmware update it just worked again. I suspect I'll continue to have issues with that disc?
    Any ideas?
    I think I've tried just about every setting I can find on the player and the TV and I'm fed up of buying and trying new cables (not to mention the cost) which seems to be all the advice I've seen seems to suggest.
  2. Ensor
    Ensor
    Nov 9, 2017
    372
    46
    Birmingham
    +114
    Have you tried connecting either of your Blu-ray players directly to the soundbar instead of via the TV to see if you can get sound that way?
  3. CRAddison
    CRAddison
    Jun 17, 2018
    3
    Stafford
    Yes it works if I connect from the Audio Out on the 4K Player directly to the Sound system, which is fine except that I would have to switch it to the other one to play through from the HDD recorder as the Sound system stupidly only has one input.
    I guess this suggests the issue is actually with the TV and the ARC functionality though?
    n.b. the HDD recorder/Blu-ray player only has one HDMI output so can't connect that one in the same way as the 4K Player.
  4. Ensor
    Ensor
    Nov 9, 2017
    372
    46
    Birmingham
    +114
    That would be my guess, which is why I was asking if all was well with the player connected directly to the sound bar.
    Take a look at the troubleshooting section here: Frequently Asked Questions for BRAVIA TV ARC (Audio Return Channel) feature | Sony UK
    There's some useful tips on how to set up the ARC functionality in the first article. Hopefully it'll help you out.
  5. CRAddison
    CRAddison
    Jun 17, 2018
    3
    Stafford
