jonny disco
(I have done loads of searching, but still unsure about the following..)
Haven't imported my Kaiboar K200 just yet due to poor £/$ atm (it ticks all my boxes, where as the PCH leaves a couple unticked)
My question is to do with formatting a brand new 1TB HDD in prep for when I get round to purchasing - and fit it inside the NMT. Sounds like EXT2/3 is the way to go if I want to use all features of this type of device, and I've read that if the NMT handles the format it will create partition(s) for various apps.
I'd rather start ripping movies to the new HDD now / before it is delivered to save time later. I realise I'll need a driver so that Windows will be able to see it / use it (it's currently sitting / waiting inside my PC atm) if I want EXT2/3, just concerned about any partition that the NMT might want in place?
The guides I've read are a bit dated, so I'm wondering if the new generation of NMTs can handle all features like Torrents, FTP, etc if I format in NTFS? I'm guessing no. Not too worried if it can't - just concered about having to start all over again from scratch if I get it wrong.
Can anyone advise please?
