nissan sat nav dvd
C
cassthebhoy
recently bought a nissan primera with manufactures own built in sat nav system (birdview) but it did'nt come with the dvd discs, looking to purchase the discs.
Chris Muriel
These do appear on Ebay.
You need to make sure you do have the DVD unit actually fitted - depends on the model and age ; if you have the player it should be visible somewhere (some were under the passenger seat).
Mine doesn't have it - got added as standard 2 months after my DCi SX was made. The colour screen is there as well as the correctly marked buttons.
Chris Muriel, Manchester
C
cassthebhoy
Thanks, the dvd player is built in on the center of the dash.
Chris Muriel
Check what price Nissan dealers charge- then check Ebay.
