Nissan Micra
Discussion in 'Motoring' started by markymark34, Dec 20, 2006.
  1. markymark34
    markymark34
    Dec 15, 2002
    3,315
    Northern Ireland
    +337
    I realise this is a rather specific question but who knows!
    My girlfriends 99 Micra has a stuck front window (manual) The lever wont budge at all (its all the way up).
    Im going to take the trim off at the weekend but would appreciate any help info anyone may have?
    thanks
    Mark
  2. Joe90sDad
    Joe90sDad
    Jan 28, 2006
    585
    28
    Location Location
    +44
    Have you tried jigging the window up and down with your hands either side while another person works the handle?
    If the window doesn't get used the mechanism can seize up.
  3. markymark34
    markymark34
    Dec 15, 2002
    3,315
    Northern Ireland
    +337
    ill give that a go at the weekend cheers.
  4. Ayub
    Ayub
    Oct 15, 2003
    6,657
    Bradford
    +612
    FIRST TRY
    Spray some wd40 on the outside seals of w/pane.
    Spray someon the inside of the handle.
    As user above stated jiggle it.
    If nothing
    remove handle ( u clip behind handle DONT LOOSE IT)
    remove trim
    window mech is in front of you.
    Spray wd40 ( yes i luv da stuff)
    along window pane which meets all the rubber strips.
    WAIT A FEW MINUTES!
    WALLA
  5. markymark34
    markymark34
    Dec 15, 2002
    3,315
    Northern Ireland
    +337
    excellent. Will let you know how i get on!
  6. markymark34
    markymark34
    Dec 15, 2002
    3,315
    Northern Ireland
    +337
    thanks guys sorted. The glue stuff at the bottom had worn out.
    Used silicone on advice from the micra owners club seems to be ok so far!
    thanks again
