chakota
Established Member
Hi all ,
Bit of a puzzle this one , 2008 nissan micra k12 160sr
Firstly , purchased car and after short time tachometer stopped working , I ended up buying second hand instrument cluster from same year micra. Tried that ... tachometer was fine on this and got my own one sorted out but discovered airbag warning light was flashing but not in my original dash. I concluded the warning light is disabled in my original dash I presume to sell the car.
Problem I got is ... on these instrument clusters there is no bulbs as they are leds integrated into the circuit board and cannot use spare dash as security system stops car from starting and will need code from nissan , which could be very expensive . I cannot get nobody to sort this flashing light problem and airbag fault has been sorted but not warning light ..... what I need to know is how the heck did they manage to disable this light on my dash as it's all ok up to the multi plug behind dash , I cannot see any where where it was disabled ....any electronic tonic experts out there who can help please ...many thanks
