Nissan Almera 2003 SE Heater Fault Help Plz
timeless
Hi Guys
The wife's Almera has a heater blower motor fault. It stopped working but Imanaged to get it working on Max speed only by shorting the earth connection onthe blower motor to the chasis. I am getting 12v on the live wire to the blowermotor. I was told it was the resistor pack at fault but the Almera SE modelwith climate control not sure if it has one, I've looked all over for it. Anyideas appreciated
Martin
Solomon Grundy
Ebay should have a load of second hand parts at a cheap enough price for a 2003 Almera, possibly think about replacing the lot.
car-man
Hi Guys
Martin
Hi,you need to replace the heater control module, located under the passenger's side dash above the footwell....very common fault on the Almera :)
Look for a connector block about 2" wide (50mm) held in by 2 screws if I remember.
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
