Nintendo Wii Problems Thread
Discussion in 'Nintendo Wii-U & 3DS' started by metalgear873, Dec 8, 2006.
  1. Ch0pper
    Ch0pper
    Mar 31, 2005
    246
    +3
    Wireless? Is your wireless set to channel 1 or 11?
  2. SHPanda
    SHPanda
    Dec 9, 2006
    152
    +6
    Great news!
  3. Red and kitty
    Red and kitty
    No issues with connectivity and updates but my points that I have registered via the nintendo website are not showing when I connect to the shop with the Wii.
    Anyone else had this issue? I only had a .B AP will that make a difference?
  4. Sicton
    Sicton
    Jul 26, 2003
    190
    Bristol, UK
    I posted this in a separate thread but here it is again:
    I set up my Wii yesterday evening to find that Wii Sports wouldn't load up, instead yielding a disc error message. I tried it a couple of times and the same thing happened. The disc drive repeatedly made the same reading sound over and over again and I tried it about three further times. Then, I unplugged the power and moved the console from horizontal to vertical position and plugged it back in again. The next time it worked and I played a quick game of Tennis. Then tried to play a game of Baseball but got the error again. I tried to load the whole game up again but the error just returned.
    I don't have any other game to test yet and my GameCube games are US games so I can't test those, either.
    Having searched a little bit on Google I found some forums of some Americans discussing the same problem and they've said it's only Wii Sports they've experienced the problem with.
    Has anyone else had this difficulty at all? Very annoying to say the least!
  5. mutamist
    mutamist
    Apr 30, 2005
    1,126
    Hitchin
    +88
    I have WiFi problems that I don't seem to be able to solve.
    My router (Belkin) is set to channel 11 (tried 1 too) and when I tried to connect I got Error Code: 52730 - Unable to connect to Internet because another device has been set up using the same IP address. Confirm network connection settings and try again.
    So, I followed the manual setup instructions on the Nintendo website (here) and I get a similar message now: Error Code: 52731 - Unable to connect to Internet because another device has been set up using the same IP address. Confirm network connection settings and try again.
    EDIT: I did a bit of tweaking and now I get a different error Error Code: 52231 - Unable to connect to the server. Please try again later.
    Edit #2: - I am now connected and updating as I type! I didn't realise Default Router was Default Gateway so didn't put anything in there - oops! Now let's see what happens!
    EDIT 3: - spoke too soon. The updates worked but now I get Error Code: 52730 = Unable to connect to the internet - arghhh!
    EDIT 4: - didn't realise I had to specify the connection - connected again! I'll go now, promise!
    Any help would be much appreciated, thanks
    Steve
  6. adda
    adda
    Jul 7, 2006
    142
    +9
    mutamist, i got a belkin too and its been actin well flakey lately. at first the wii found it fine, very straightforward, i didnt need to alter any settings... then it all started goin wrong, not findin an access point, timin out and numerous error codes etc. even lost it on my pc in the end?
    anyway point is rather than titting about with it any longer, i just pressed the little reset button on the back and its came back fine with no messin and is now runnin smoothly. just bought some wii points an about to choose a game :)
    so maybe yours is just a flake like mine? cos it aint supposed to be this difficult.
    good luck anyway!
  7. mutamist
    mutamist
    Apr 30, 2005
    1,126
    Hitchin
    +88
    Thanks adda - if I get any problems, hitting reset will certainly be my first port of call.
    Right now I'm stuck surfing the net and reading the paper while the wife watches X-Factor, all I want to do is get the Wii back on and find my Wii code thingy!
  8. C225
    C225
    May 15, 2006
    6,257
    Linlithgow
    +773
    My wii has develpoed a weird problem since the forecast update yesterday. Now at times when either loading games or coming back to the Wii menu from channels the controllers lose sync and refuse to reconnect to the console. The only way to fix it is to remove the power cord wait a minute and reconnect it. Thing is it does it completly randomly as sometimes it works fine and other times it happens.
    Anyone else noticed this since the update yesterday or is my console on the way out(please no:rolleyes: )
  9. Darbo
    Darbo
    Apr 12, 2006
    158
    +13
    Woke up this morning, turned on the wii for a gander at the weather channel, error 107245, cannot get latest weather update....ok, think i'll try to download the internet channel, nope...error 200004 can't do that either.
    Anyone know whats goin on? it was fine last night.
  10. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    I had a similar problem, my router was on channel 6 and working fine for a week,
    then one morning it couldn't connect?
    I set up an access point on channel 1 to see if it would work and it did,
    so i've now change my router to channel 1 and everything seems ok again.
    Bloody annoying though because i've got 2 wireless laptops and a wifi printer which all need to be told of the router's new settings!
    What if all my neighbours buy a wii too? i ca already see 1 week signal on channel 1
  11. j98
    j98
    Jan 30, 2005
    344
    +12
    I've had a similar problem with both Wii Sports and Zelda! I haven't got any error messages, but when my Wii was in the upright position it sometimes had difficulty reading the discs. Loading took ages and I could hear the drive clunking away trying to read the disc. Then the system would hang and need to be reset.
    It hasn't crashed since I put the console in the horizontal position but I do occasionally notice the drive noise while playing. Is this normal?
  12. Matt TRD
    Matt TRD
    Jun 28, 2005
    954
    Poole
    +68
    Ok here's another strange one I cannot turm my Wii on.:rotfl:
    It is in standby mode and showing a yellow status light as I leave it connected to the internet, and the blue light is glowing indicating I have mail.
    But no matter what i do I cannot seem to turn it on, very strange as it was fine this afternoon.:mad:
  13. Hornet2112
    Hornet2112
    Apr 29, 2006
    274
    +63
    Try unplugging it from the mains for a few minutes, I remember this happening to me and it seemed to fix the problem.
  14. kpkiller
    kpkiller
    Had the same problem - got round the issue by doing a manual sync of the controllers by removing both of the controllers under the remote settings and pressing the Red sync buttons on the controller (under the battery flap) and on the Wii console (under the disc drive).
    Since then I have had no further issues - putting it down to a system update or some thing.
  15. Matt TRD
    Matt TRD
    Jun 28, 2005
    954
    Poole
    +68
    Yeah after an extensive search last night I finally found some information on the problem.
    Apparently when you enable Wii connect 24 the console remains active even when switched off due to the connect 24 but unfortunately the fans are switched off which leads to the console overheating.
    So I unplugged everything let it cool down as it was very hot. It is now all ok and I have disabled connect 24 in the settings.
    Thanks for trying to help though much appreciated.:smashin:
  16. dazza74
    dazza74
    Aug 24, 2006
    13,031
    +1,394
    I've had a load of problem with mine even with it horizontal, like you said in particular Wii Sports you know it's not going to work when it's does the disc clicking my normal solution is to reset it and put in Wii Play which seems to fix it then I just reload Wii Sports. Guess I'll have to live with it for at least the time being as I don't think I can get a replacement from Argos at the minute!! I wonder whether the Wii needs to warm up a bit before it works properly I don't seem to get any issues once I get it up and running
  17. smashie
    smashie
    Apr 20, 2006
    832
    great yarmouth OOOAAAR!
    +51
    my tv keeps losing sync when bright flashes appear on the screen, such as a strike in bowling and when you get a perfect in the raving rabbids dance game, i have it all hooked up via official component leads to my hyundai imagequest q321 (which by the way deals with my 360 and htpc outputs of 1366x768 flawlessly!) set to output at 480p and 16:9, have also tried all resolutions and format permutations.. its a real pain!!
  18. Billy Hunt
    Billy Hunt
    Jun 29, 2002
    1,185
    Worksop
    +98
    I think my Wii has been overheating I also leave Wii connect 24 on.
    But isn't that the idea?
    It's even turned its self off a couple of times during game play.
    Think I'll contact Nintendo to see what the score is or what my options are on getting it replaced or repaired
  19. Refused
    Refused
    Oct 10, 2006
    896
    Andover, Hampshire
    +85
    My play time on the wii is only counted the first time i play a game or use a channel. After that it just gets added under others. Is this usual?
  20. Looeewoo
    Looeewoo
    May 12, 2006
    477
    Edinburgh
    +34
    Just in time for the holiday weekend my Wii has started crashing repeatedly and I can't get it to read discs. :mad:
    I've tried the Wii on it's stand and on it's side and I really don't think it's an overheating issue - I can play VC games for hours with no problem.
    Used to get the occasional crash in Wii Sports, usually on a menu change but it's become more and more regular and as of last night it was happening several times an hour.
    As a last resort before calling Nintendo I was going to clear the Wii memory. I've backed up all my games to SD, but as Wii Sports uses the Mii-s then am I right in saying that all my saved Sports data will be useless if the Mii-s are bumped with the memory flush?
  21. coluigi
    coluigi
    Jan 9, 2007
    1,290
    Manchester
    +86
    Not sure about that, but Warioware retains the data if the Miis get lost.
    But, you can save Miis to a remote - that may work.
  22. Looeewoo
    Looeewoo
    May 12, 2006
    477
    Edinburgh
    +34
    It says in the Sport manual that Miis saved to a remote dont have their scores saved - albeit I guess this means if you're playing with them on another Wii.
    Do you think that if you can save them to the remote can they be copied back to the Wii so that Sports will match them to the saved game data?
  23. coluigi
    coluigi
    Jan 9, 2007
    1,290
    Manchester
    +86
    Possibly yes, but in the worst case scenario you get to power through Wii Sports again.
  24. Tetlee
    Tetlee
    Jan 21, 2004
    20,310
    Taunton
    +4,806
    If I understand correctly from other peoples comments, if sent back to Nintendo they transfer all your data including Mii's over to your replacement console. I can't confirm this but I'm sure I read someone mentioning this previously.
    Will merge this thread into the Wii Problems thread, might be worth reading back through that one incase it has been mentioned there already.
  25. Looeewoo
    Looeewoo
    May 12, 2006
    477
    Edinburgh
    +34
    Yeah, in the manual it states that you have to return your Wii to Nintendo for repair directly, otherwise you'll lose all your saved data, VC games etc.
    So I'll phone them on Tuesday for an RA or whatever and we'll start the clock.
    Has anyone here already been through this process?
  26. Looeewoo
    Looeewoo
    May 12, 2006
    477
    Edinburgh
    +34
    Ok, phoned Nintendo CS this morning starting at 10:10 - 20 minutes of 'number busy, please try again later' & ringing out.
    Eventually got through to a pleasant chap who agreed that the console would have to go back to them. He reckoned they'd turn it around in a week, so the clock starts now. There's no Returns number issued, so if you're sure your box is stuffed beyond telephone support I don't see any need to call first.
    Boxed up the Wii (console only) with a covering note stating the problems, serial number & proof of purchase. Addressed the label as per the Returns address on the website, adding 'Wii Service Centre' at the top of the label, as the guy said this would speed things along a bit. Took it up to the PO (another 15 mins in queue :( )and sent it Next Day Special Delivery insured for £7.75. Intend to claim this back from Nintendo later.
    PS: I also tried emailing Nintendo yesterday while trying to get through on the phone. 27 hours later and still no reply, so I'd forget going down that route...:thumbsdow
    ^ eventually got a reply to the email (14:20 Thursday), just says what the guy said on the phone, i.e. send it back.
  27. Zaichik
    Zaichik
    Mar 5, 2002
    1,585
    116
    +665
    I went to play on my Wii after about a month of non-use and found that the batteries on both my Wii-motes had expired. Is it normal for them to run down so quickly when the Wii isn't being used?
  28. Looeewoo
    Looeewoo
    May 12, 2006
    477
    Edinburgh
    +34
    Although we have 2 remotes, one gets used far more than the other. When the 1st remote's batteries died I switched out the ones in no. 2 but they were dead too, so I guess there must be a drain there (possibly the bluetooth sync?).
    Anyway, a good reason for getting rechargeables ;)
  29. Ch0pper
    Ch0pper
    Mar 31, 2005
    246
    +3
    Were the Wiimotes in a drawer or out in the open?
    If something is leaning on the buttons it can use up the batteries pretty quickly. They seem to deplete quicker when a nunchuck is plugged in too.
  30. Looeewoo
    Looeewoo
    May 12, 2006
    477
    Edinburgh
    +34
    Mine were lying out, nunchucks not plugged in.
