Nintaus N9769 Progressive scan player
Discussion in 'Projectors, Screens & Video Processors' started by Kramer, Mar 21, 2002.
  1. Kramer
    Kramer
  2. kota
    kota
    Apr 2, 2002
    61
    9
    Sintra - Portugal
    So .. how good is it ??
  3. Timh
    Timh
    Sep 14, 2000
    5,223
    3
    3
    Altair-4
    +310
    check out the dvd hardware section.
  4. Halcion
    Halcion
    Oct 11, 2001
    78
    9
    Quite good, but not reliable.
    It will freeze or jerk the movie several times when looking a single movie.
    It will lock up or show really bad compression artifacts on badly pressed or scratched discs.
    However, it can be firmware upgraded and the DVD-ROM can be changed.
    If a suitable replacement drive can be found and firmware bugs corrected, this will be one hell of a player for the price.
    cheers,
    Halcyon
    PS A price notch above is Philips 962SA with multi-channel SACD and PAL progressive with Faroudja DCDi. Based on my preliminary testing the DVD performance is flawless, only some slight cropping of image (very common with all players).
