Nintaus N9769 dvd broken
Discussion in 'Blu-ray & DVD Players & Recorders' started by jimhoyle, Aug 17, 2005.
  1. jimhoyle
    jimhoyle
    Some people here seem to have (had) this dvd player, Nintaus N9769. Now mine is broken, the internal power supply seems to be broken (no power, no lights, nothing). There is this component in the middle of the power supply board, check it in the attached picture. It says something like (HX) BCK-03/N769. It is making little chirping noise about every 750ms or so when I switch the power on (power button down). Or at least I believe it's this component that is making the noise.
    Any advice, can I replace this component perhaps?
    If there's nothing to be done, then what's the cheapest equivalent dvd player out there today? Good quality progressive scan player with VGA output that is.
