NiMh battery charger
Discussion in 'Photography Forums' started by petrobas, Dec 26, 2002.
  1. petrobas
    petrobas
    Any recommendations for a good NiMh battery charger to charge 1600Mah Kodak batteries .
  2. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    Whenever I have asked this question, the MAHA CF204 has been the one recomended time and time again.
    I have only found 1 UK supplier (http://www.mahaenergy.co.uk/acatalog/index.html) and am planning on ordering mine when I get the chance.
    The Maha one has the advantage that it will condition the batteries when needed, and should fully charge a set of 1800mha batteries in about 3 hours after which it is inteligent enough to realise they are fully charged and drop down to trickle charge.
    I have been warned off the 1 hour chargers as they can get too hot and also the cheap chargers (like the one that came with my batteries) as they will charge for a fixed amount of time (16 hours in my case) regardless of how much charge is left in the batteries to start with.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    I've got the Ansmann Powerline 4 charger. It has changeable plugs so it can be used abroad (also multi voltage) and comes with 4 2000mAh AA batteries.
    I got it from www.fotosense.co.uk
    Mark.
  4. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    Does that one have the ability to discharge and condition the batteries first and does it run cool?
  5. petrobas
    petrobas
  6. garywork
    garywork
    Not cheap are they !
    :eek:
  7. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    Well not for a good one, no.
    Of course you could always buy a cheap £10 one but then you don't know how long your batteries are going to last.
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    At the end of the day, you get what you pay for.
    Spend a little bit more now, and save more in the long term. Quality will last a lot longer than cheep and chearful.
  9. BK Electronics
    BK Electronics
    Active Member AVForums Sponsor
    Aug 10, 2002
    376
    Essex
    +25
    I bought my charger and 4 1800mA Bateries for £15.00 does this mean there going to die on me quickly. My charger charges for about 2.5 hours then goes on to trickle charge.
