Nikon Unveils New D4 Flagship D-SLR
johnaalex
Thanks to Nikon Rumours....
Greg Tarr
Released : Tuesday, January 10, 2012 12:01 AM
The Nikon D4, which is slated for February availability at a $6,000 suggested retail, will offer a full-frame 16.2-megapixel full-format CMOS image sensor that will shoot full-resolution images at up to a 10 fps rate.
The camera is also one of the first to support the new XQD Compact Flash memory card format, and will also offer a second card for more conventional CF cards.
The Nikon D4 has improved low-light performance, with an ISO range from 100 to 102,400 which can be expanded to 50 to 204,800 for both movies and stills.
The D4 also improves on the D3's color matrix metering system with a third-generation 91,000-pixel RGB metering sensor.
The unit takes the AF mode select switch from the D7000 and uses improved 51-point AF points with 9 cross-type sensor and a beefed up AF module allowing focus with an f/8 lens and faster (up from f/5.6). The AF detection range is now down to EV-2.0
The viewfinder features a full pentaprism with a 100 percent field of view.
The video section will record pixel-for-pixel Full-HD 1080p resolution with selections for 30p and 24p frame rates in this iteration, and 720p at up to 60p for slow-motion work. The camera now includes support for the H.264 B frame compression scheme.
The camera uses contrast detect AF in movie recording and features a low-pass filter optimized to maximize sharpness of HD video, meaning greater noise reduction when shooting full-frame movies.
Function buttons are illuminated this year, and a dedicated video button (user re-assignable) is added near the shutter button.
The D4 supports WTSA wireless control using the optional Nikon WT-5 wireless transmitter, and features an integrated Ethernet port and HDMI output enabling output of uncompressed video.
The D4 also introduces face detection/recognition into the flagship series
Another new feature is smooth aperture control for use while shooting video.
At the same time, the company introduced the Nikkor AF-S 85mm f/1.8G FX format lens ($500 suggested retail).
The company said the D4 is not being produced in Thailand will not have production issues from the recent flooding situation there. But whether the company will have enough supply to meet the expected demand from Nikon-aligned professional photographers and converts remains to be seen.
2012 International Press Telecommunications Council
twist
So much for the 36MP Sony sensor. Surprised they called it the D4 as it supposedly sounds like death or something in Chinese. No doubt it will be a killer camera.
johnaalex
johnaalex
More details HERE
Better buy a lottery ticket ;)
Chubster
Well I spose I have had the D7000 for at least a month....MUST be time for an upgrade surely ?
Johnmcl7
£4,800 - was the D3 as expensive as that on its initial release, seems a lot higher than I thought it was.
John
Ian_S
The D3 was £3399 at launch, the D3s was £3665, so yes, a fair jump in price, as per their main rival seems to have done too....
Jammyb
From DPReview
WT-5 Wireless Transmitter with web-browser camera control interface
With the D4 comes a new WiFi transmitter, the WT-5, which is a neat little unit that screws onto the side of the body and draws it's power from the camera's battery. Its real party trick, though, is a built-in web browser-based remote camera control interface that doesn't require you to download or install a specialized app. Essentially, you can log into your camera (with a username and password) using your laptop, tablet or smartphone and its standard web browser, at which point you're presented with a camera control panel with live view feed. You can adjust a wide range of parameters - exposure mode, shutter speed, aperture, exposure compensation, ISO, white balance and so on, and initiate remote shutter release or video recording.
The WT-5 connects to the socket on the lower left of this image. In the center you can see the microphone and headphone sockets. On the lower right is the Ethernet port.
The web interface also allows you to control multiple cameras simultaneously, including the ability to release their shutters simultaneously. You can even autofocus anywhere in the scene, simply by touching your iPhone or iPad's screen. Because this is all web-based, you don't have to physically close to the camera either - in principle you could operate it from a different continent.
Nikon has clearly paid attention to professional photographers' workflow requirements when shooting, and has tried to set the camera up so there's no need to use a laptop alongside it any more. To this end the D4 allows photographers to add full IPTC data to all of their image files as they shoot, and can store 10 data presets each containing 14 fields. There's a new network setup wizard to configure the camera for use over wired LAN, or WiFi in FTP and HTTP mode. The camera can even use the GP-1 GPS receiver to automatically set its internal clock, so multiple cameras can easily be synced and specific events from a shoot identified by the time at which they occurred.
Seem to remember a discussion on this not so long ago with people saying why would a manufacturer bother?
Similar threads
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
Trending threads
