Nikon remote shutter release
Biscuit761
Am thinking of buying the Nikon ML-L3 Infra Red remote shutter release as sold here
//http://cgi.ebay.co.uk/Nikon-ML-L3-IR-Remote-Control-D50-D70-D70s-Kit-8800_W0QQitemZ160065659251QQihZ006QQcategoryZ64345QQrdZ1QQcmdZViewItem
One question, as far as I can tell the sensor on a D50 is on the front, what happens if you are standing behind the camera ? Does it still work ?
Bill
onefivenine
Infra Red is a line-of-sight transmission, so unless you have a mirror, it'll work as well as a DVD remote does when the dog stands in front of the player. Indoors you might be lucky - it might reflect off something else, but outdoors - forget it.
Saying that - maybe they've been clever and there is a light leak to the sensor via the viewfiinder or something. Unless you cover up the view finder when shooting!
beachy
Bill
bill the link to this page is'ent working, but if is the same IR as i got from ebay, it works fine even if i stand behind the camera or to the side.
PaulBoy
Bill
Bill - I had one of these when I had my D50 & found it only worked when the remote was almost next to the camera (i.e. within inches) - maybe I had a poor one but for £10-£15 don't expect too much - This remote doesn't work with my D200 so I bought a Zigview one which works anywhere within 10-20m (but did cost £50)
Paul ;)
blicky_1
I purchased one of these from ebay (HK) a few months ago, the range on my D70s is very good. If you want to use it behind the camera just set it up for a few seconds on self timer with remote (this is what I have been using on long exposure night shots on a tripod) and it works great :thumbsup:
mr_b_at_home
Do you have a programmable remote (philips pronto) ? If so go to remotecentral.com and you can find the infrared signal in a ccf file that has been kindly posted up :)
Saves buying the remote :clap:
Biscuit761
Main reason for wanting a remote is to be able to take action and firework shots, all my last years fireworks were taken using the remote cable on my FZ20, also I take pictures at concerts occaisionaly and you want to be able to fire at the right time.
Am aghast that Nikon did not make a better option for this.
Bill
Similar threads
