nikon d50 which lens
Discussion in 'Photography Forums' started by ftmftm, Sep 4, 2005.
  1. ftmftm
    ftmftm
    May 15, 2005
    101
    sunderland
    hi all, this is my first post, ive been looking on this site for a couple of months now and very keen to learn more. im after some advice, ive just bought an nikon d50 and the kit lens 18 - 55, im new to the slr game, i want another lens and been looking at Tamron 28-300mm f/3.5-6.3 XR DI and a
    Sigma 28-300mm f/3.5-6.3 MACRO Lens. my question is which one will be better for me, i want to take close ups and zoom pic's aswell, any help and advice would be welcome, thanks
  2. RobertP
    RobertP
    Nov 21, 2002
    529
    19
    Woodford Essex
    Welcome.
    A Nikon user will be along shortly :)
    In the mean time there are plently of lens review sites around Fred Miranda is not a bad place to start.
    Not looked at reviews for your choices - initial thought is that extreme range zooms ie short to very long usually have compromises - so a medium to long zoom might be a better choice as you already have the kit lens range.
  3. Thomas Gee
    Thomas Gee
    I agree with RobertP. I have also a Nikon D50 with the kit lens. I have got for myself a 70-300mm lens. If you have a 18-55mm lens and if you intend to get the 28-200mm lens, you might as well disposed of the kit lens since the other zoom would duplicate the kit lens. Just my two sens.
  4. ftmftm
    ftmftm
    May 15, 2005
    101
    sunderland
    thanks lads, what about these's
    Sigma 70-300mm for Nikon AF f4.0-5.6 DG APO Macro
    Sigma: 70-300mm F4-5.6 APO Macro Super II Lens
    Tamron AF 70-300mm f/4-5.6 LD Macro for Nikon
  5. Radiohead
    Radiohead
    Dec 24, 2001
    4,396
    Amazingstoke
    +432
    The Sigma APO is a cracking lens for the money - that's where my cash would go. I'd give the DG version a swerve if you can pick up a non-DG for less money.
