Nike+
bigdavecox90
I did a search and couldn't really find my answer.
Just wondering guys...what do I need to do to use the Nike+ app type thing on the 3GS?
cuttsy
You just need to buy a sensor and a way of attaching it to your shoe if you don't have Nike+ trainers as per the first two on this amazon search
Amazon.co.uk: nike + sensor
Start up the Nike+ app on your phone link the sensor in the settings on your phone follow the instructions on the app and go running. (worth while calibrating the Iphone on a measured run as mine was telling me I had finished a half marathon at Mile 11.)
Then set up an account on the Nike+ website sync with itunes and it sends the data to the Nike+website and you can follow your progress.
Excellent stuff.
Desmo
What exactly does it measure? Just distance? Might as well use one of the many apps that does that via GPS.
cuttsy
But I don't think you can listen to your music at the same time or lets you take calls etc might be wrong. The New Nike + website also lets you challenge friends and keep a track on each others achievements so quite a good motivator.
Nike+ also gives you feedback on runs like how far to go and PB times on the go.
bonchai
I was going to get one of these but the battery can not be changed! Once it goes dead you have to buy a brand new unit.
Miyazaki
Has anyone got runkeeper pro?
I have ordered the nike+ sensor, but was wondering if runkeeper pro is better?
KaidM
I have been using Run Keeper Pro for about 2 months.
I really like it.
You can listen to music at the same time and the app then maps your route onto google maps. Keeps a record of workouts so you can review your progress.
Also allows you to specify whether you are running, hiking or cycling.
You can receive an update every 5 minutes on distance and pace covered as well as a work out summary.
Also started to tweet my workouts on facebook which is great for getting encouragement from friends etc.
So overall yes would recommend.
Kaid
