Nightshot/Super Nightshot?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by dockerslund, Sep 2, 2003.
  1. dockerslund
    dockerslund
    Feb 14, 2003
    57
    South London
    Is there a huge difference in quality between Nightshot and Super Nightshot?
  2. 1664
    1664
    Nightshot will allow you to film in dark conditions, the picture will be mainly green ish, super nightshot will allow you to film in almost pitch black conditions, however you will probably need a tripod, and pan and zooming will make the pitcure blur as it uses a very slow shutter speed, any motion will also probably blur
    Hope that helps
  3. dockerslund
    dockerslund
    Feb 14, 2003
    57
    South London
    Ok, thanks.
  4. 1664
    1664
    Yep !
    Nightshot is watchable, supernightshot is very very jerky if you move the camera, hence it needs to be on a tripod, and do not pan or zoom if you want focused pictures, good for looking down the garden at night to see whats there but not much else.
