Nightshooting and New camera buying
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by emneild, Sep 23, 2003.
  1. emneild
    emneild
    Hello there, I am interested in buying my first camcorder. From the research I have done I want the following features:
    mini-dv format,
    Dv-in/out,
    Analogue in,
    nightshot (0 lux),
    image stabiliser,
    (widescreen).
    I have come to the conclusion that the Sony PC105 would be a sensible way forward.
    What do you think of this camera?
    Also is the Nightshot feature any good? Does it work? Is it true that you can buy an add-on so that it works better? Does it only work in still camera mode or does it work in camcorder mode as well?
    Lots of questions I know, so thanks for you time.
    Mark.
  2. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    I can't specifically answer in regards to the PC105, but I've had 3 Sony camcorders and can say that, assuming the nightshot on the PC105 is the same, then it is very good, as long as you don't mind greenish black and white pictures. This is because they use an infra red light source. It does work in camcorder mode (never tried it in still mode but assume it's the same). I don't know of any add on to make it better, but that's not to say there isn't one!
