Nightmare
vegasmtv
I remember when buying a electronic device was simple.
Well im tryint to buy a dvd recorder so i can put movies form the sky movies channels form my sky + box to a dvd.
I need rgb input, a dvi input for my camcorder, divx playback and something that can be made multi region with the remote.
I have been to comet who had the dvp-vr320 which seemed good but apparently if you region hack it you will need to do it EVERYTIME you turn on the player.
I looked at the Samsung dvdr120, they had no stock.
I looked at the samsung dvdr122, had no dvi input.
I have spent at least 20 hours on the net looking for a decent player which has the things i need but EVERY player i come accross i read horrid reviews for.
CAN ANYONE RECOMEND A GOOD DVD RECORDER WITH DIVX PLAYBACK, DVI INPUT AND A REMOTE REGION HACK BEING AVAILABLE FOR IT WOULD BE GREAT.
Thanks.
Im done looking if no one replies im just not going to get annoyed more and more.
vegasmtv
I have also read about dvd recorder where when you record a dvd with it, it would not play in most other dvd players.
Any one know of a player that has great compatability?
Trending threads
