ChrisLledrod
Where do i start.....
Last week, my pc (Windows 7 Home Premium) gave me the blue screen. It didn't want to start. System restore didn't work. Repair either. I reinstalled windows. Worked fine for a day.
Next day, back to boot troubles. restarted it few times and played around with bios settings and it started up again. Fine for a day or so.
I had enough when it stopped working again. Bought a second hand tower on ebay. Pretty much the same pc, but with different hardware, which doesn't make sense but everything was compatible with both motherboards.
I swapped my old CPU ( quad core ) replacing the dual core. Put in my ram (4gb) replacing the 2gb. Swapped the PSU, replacing 180W with 300W. Leaving the HDD, as previous OS problems are best left behind. My previous tower had worse integrated GPU than the replacement tower, and faster USB etc.
Switched it on and it's worked a dream. All day. It's recognized everything correctly, so i thought all was good. I then put in my old HDD alongside the other HDD, connected it to SATA port 3, so that i could transfer old files. That was recognized and all seemed good. I made sure that in BIOS windows would boot from the newer C drive, not the old HDD. It worked.
After 5 hours of tinkering, correcting WIFI card problems etc, it randomly gave me bluescreen again. Different tower, same problem. Must be an old HDD problem, but what do i know. See attached image of blue screen.
So i've tried repair again. It stalled half way through. Switched off. And now when i turn the tower on the monitor doesn't even get a signal, light on tower, nothing on screen. What a headache.
Do you guys reckon it's a problem with my old harddrive? A virus maybe? Considering the OS isn't even running off that HDD, it confuses me how the system can freak out when it's essentially connected as storage only. Please help me if you have any idea.
Cheers in advance.
Chris
Cheers in advance.
Chris
