Nice looking Cable Trunking
Discussion in 'Home Cinema Building DIY' started by FullFat, Apr 13, 2005.
  1. FullFat
    FullFat
    Sep 30, 2004
    934
    Warrington, Cheshire
    +51
    Hi all,
    I've wall mounted our new lcd screen in the bedroom and need to hide the cable connections in some nice looking trunking. The wife would prefer a chrome faced look to the trunking but I can't seem to find any at all. She swears that she saw it "on that decorating program"!
    Embedding them in the wall is not an option at the moment as the wall is papered and I don't have the time to redecorate the whole room!
    Any suggestions or pointers would be gratefully received!
  2. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    what connections do u have to hide? video and power?
  3. FullFat
    FullFat
    Sep 30, 2004
    934
    +51
    I need to hide one power cable 1 scart (round) and an Svideo + 2rca phono flattish type cable. The svideo one is the widest at about 20 - 25mm (that's from memory as I'm at work at the moment.)
    Cheers.
  4. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,232
    Middlesbrough
    +140
    Have you thought about using some sort of pipe or conduit.
    You will find it much easier to source decorative piping than
    trunking.
    Just a thought.
    There are some great examples of using two pipes, to look
    like a stand, in the plasmas out for the lads thread.
    Johnny.
  5. FullFat
    FullFat
    Sep 30, 2004
    934
    +51
    Cheers Johnny, I had thought that that might be the way I ended up going. I'll have a look throughthe thread and see what's possible!
  6. steve24855
    steve24855
    Aug 20, 2003
    32
    Pontypool South Wales
    Fullfat
    You could try this web site http://www.tlc-direct.co.uk they are electical wholesalers or you might try somewhere like plumb centre or some of the plumbing web sites.
    BRGDS
    Steve
  7. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,232
    Middlesbrough
    +140
    Fullfat
    Just a thought, but, can you access the other side of the wall.
    Is it within your property, and in need of decorating?????
    It's not ideal, but it is an option.
    Johnny.
  8. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    to be honest no trunking can look nice :suicide:
  9. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I mounted a false wall behind my LCD. i.e. large piece of plaster board wallpapered to match the room, slightly wider than the set and running from slightly above it to the the floor. all cables go through it and down to floor level where they can be hidden under edge of carpet (if you have one). mounting bracket goes though the plaster board to the real wall of course
    Probably a bit more DIY than you were planning on, it took me a couple of days, I think it similar to what some profesional installers do, but it does avoid any trunking and it is quite cheap.
    PS used TLC for electrical stuff mentioned above and they are very reliable.
