Nicam, Virtual, 5.1?
Discussion in 'General TV Discussions Forum' started by Donnie, May 28, 2003.
  1. Donnie
    Donnie
    Advice please!
    Is virtual dolby with a built in subwoofer a great improvement of sound, compared to nicam, when watching terrestrial or sky sports?
    If you have a 5.1 cinema kit does this only work when playing a 5.1 dvd is it worth getting this sort of kit if mainly going to be watching sky?
    Its all getting to much for my little head!!!!!!!!please help!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    You are a bit confused matey! A thread .HERE might help a bit. Virtual Dolby is a Stereo processing effect and not great.
    Read that thread and see if you understand a bit more!
  3. Donnie
    Donnie
    More than confused! Thanks for the info!
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    So did that help anything you dont understand then you can search the Forum for previous threads on a topic.
  5. Donnie
    Donnie
    Right read the thread think i got it but not sure!
    1) Virtual dolby not to much of an improvement?
    2) Dolby 5.1 not worth it unless watching dvd's or some sky+?
    So am i right in thinking that pro logic 2 will be the best for getting crowd atmosphere through sky sports?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Yep you are matey!!! DPL2 Works well with all stereo sources, VHS, TV etc. As for Sports never listened specifically to any sport(footie I assume) in PL2. You might want to try it before you buy! But currently there are no systems for making a stereo source surround.
  7. Donnie
    Donnie
    Cheers mate thanks for your time!
  8. Donnie
    Donnie
    Thinking of getting the panasonic 32PS12 tele as her indoor's only likes the panasonic "styling" ( don't ask! ) will this have all the proper connections for the amp? Is it any good?
