Ni-MH or NiCad batteries?
Discussion in 'Photography Forums' started by mellow, Jun 5, 2003.
  1. mellow
    mellow
    A bit off topic I know but:
    I know that Ni-Mh batteries are better for high-drain equipment, like our digital cameras, but does this go for all battery-powered equipment?
    I want to get more "eco-friendly" and replace the alkaline batteries (as they wear out) in the low-drain appliances round the house (clocks, remotes, etc). Can anyone comment whether the power characteristics of NI-Mh or NiCad are better for this type of device, or is there no real difference?
  2. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    If "eco friendly" is your motive then toxic Cadmium might be best avoided!
    Ni-Mh are your best bet. They have no memory effect so you can charge them when you feel like it. 2 points to bare in mind - the terminal voltage is 1.2V for rechargeables (alkaline etc are 1.5V) though most devices won't have a problem, and Ni-Mh do self discharge though it will be some months before they go flat sitting on a shelf (or inside a clock)
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,975
    Avoid NiCd. The 'memory effect' makes them unsuitable for any electronics where the battery is not fully discharged prior to the appliance cutting out. NiMH does not suffer this problem.
