NhaNc3 Rips. How do I convert them to a ps3 compatible format?
Discussion in 'Blu-ray & DVD discs' started by johnslone55, Jan 18, 2008.
  1. johnslone55
    johnslone55
    Those of you know who I'm talking about will know that those nHD releases cant be played on the ps3. PS3 Video 9 doesent work in converting them either, so I was wondering, how do I convert their HD releases to either mp4 or divx or w/e?
    I belive that the audio is AAC, and that the video is avc1. Can anyone help
  2. ndenbow
    ndenbow
    Oct 20, 2003
    495
    Herts
    +12
    I had a similar problem with Encode360 with some of these files. I narrowed it down to the audio codec and never resolved it. I tried the Combine COmmunity Codec pack and K-Lite and nothing I tried worked. There were a few cryptic clues on the Encode360 forum site but nothing definitive.
    The only way I could get the re-encode to complete was to down-mix the audio to 2-channel. I think the offending audio format was A_AAC 6-channel? Sometimes NhaNc3 uses a slightly different format which does go through ok on 6-channel.
    Hope that helps.
  3. ndenbow
    ndenbow
    Oct 20, 2003
    495
    Herts
    +12
    Hope that helps.
  4. Stoke192
    Stoke192
    Oct 30, 2005
    5,640
    Wirral..Cheshire
    +2,055
    You'll get a better response on the PS3 boards to your conversion probs :)
