Nforce 2 problem
Discussion in 'Desktop & Laptop Computers Forum' started by fromheretodeath, May 10, 2005.
  1. fromheretodeath
    fromheretodeath
    Hey, I've got 6.1 creative speakers but I only use them as 5.1 because I have onboard nforce 2 audio (which is only 5.1 compatible). My motherboard is an a7n8x2.0 deluxe. I've installed all the latest drivers from the nforce website. The problem is, I use the speaker wizard to set up my speakers. The speaker wizard detects all the speakers and plays a sound through each speaker (front left, front right, rear left, rear right, front centre and sub) and sound IS produced from each speaker. When it reaches the end of the setup it plays a song, this is where the problem occurs. No sound is produced from either the centre speaker or the subwoofer and I don't know how to make it work. I've tried pretty much everythin I can think of, so if ne1 out there can help i'd be grateful. Cheers for your time.
  2. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    I've got the same Mobo and I ended up rolling the drivers back to the older easier to work with ones.
  3. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    same here, roll back or reinstall the old soundstorm drivers.
  4. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    Same here - used one of the early drivers - they are more configurable.
