Nfl 2k3
Discussion in 'Nintendo Forums' started by scrapbook, Nov 19, 2003.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,422
    +550
    A forum fav this game by all account so...
    Just a quickie -
    When selecting which team to control what does 'Maximum Passing' mean. It makes reference to it in the manual, but no explanation!
  2. Azrikam
    Azrikam
    From what I've read, and from playing the Dreamcast version, it's thus:
    Maximum passing allows you to over or under-throw your target (the intended received) by using the analog stick. Pushing up when you pass will fire the ball farther, pushing left will curve the pass to the left, etc.
    Pushed too far, it's an easy way to throw an incomplete or intercepted pass. But used correctly, it can really make a difference in your offense.
