Nextbase DMV4
Discussion in 'Blu-ray & DVD Players & Recorders' started by rdcox, Jan 27, 2003.
  1. rdcox
    rdcox
    Dec 20, 2002
    13
    3
    I'm considering buying a Nextbase DMV4 portable DVD player for use in car/home as a second DVD player to my Sony 725D which unfortunately doesn't play RCE Region 1 disks as it was modified before RCE came out. I'll be hooking in via sVideo (to projector) and scart (TV) and hopefully later to a couple of in-car screens.
    How do you guys rate this player and does it definitely play RCE disks without modification? Also, other than ebay, do you know of anywhere else I can get a good deal on the player.
    Thanks for any feedback.
  2. cslogg
    cslogg
    Jan 22, 2003
    55
    UK
    rdcox,
    I cannot answer your RCE query I am afraid,I just know it has played every disc I have put in it.I purchased mine from
    www.merconnet.com for just under £90 just before Christmas.
    Postage was a bit hefty on top of that but if you are near London you can pick it up from the supplier.The website does some good in car screens as well.
    cslogg
