Next-Gen Consoles & HDMI/DVI
Discussion in 'LCD & LED LCD TVs Forum' started by Logan09, May 30, 2005.
Tags:
  1. Logan09
    Logan09
    May 27, 2005
    65
    Does anyone know whether the next-gen consoles will require a HDMI input, or whether you could use a DVI (non-HDCP) with an adapter?
    I know you will be able to connect them by RGB/Component as well, but I'm talking about the best possible connection. I was basically wondering if I buy a Toshiba 27WL55 then will I be able to use a DVI-to-HDMI adapter with the Xbox360/PS3?
  2. SIDEARM
    SIDEARM
    PS3 will have HDMI out as standard so you can just use an HDMI -> DVI converter, no probs. XBOX 360 has a proprietary AV out just like the XBOX. It is digital so there is no reason why a range of cables shouldnt be available covering any type of connection you want. What we do know is it comes with a component cable in the box, so you will have to pay extra for a digital cable.
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Xbox 360 comes with a Component Cable in the box? Wow - that is very surprising. I guess they really are serious about pushing the HD side of it.
    Also I can think of no reason why Component cables wouldn't be made available for the next generation consoles. However, they probably won't output High-Def movies over them (they'll probably be scaled down to Standard Def) due to there being no form of copy protection that Hollywood deems safe.
  4. SIDEARM
    SIDEARM
    Well they have confirmed a component cable in the box for the US market anyway, heres hoping theyre not going to shaft us by just giving the UK a composite or something.
  5. SIDEARM
    SIDEARM
    Ooh confirmed: XBOX 360 comes with a single cable that has both composite and component connectors on it. Pic here: http://img283.echo.cx/my.php?image=360hdadapter8fm.jpg
    Also there is an official VGA cable now. Pic here: http://img266.echo.cx/my.php?image=360vgaadapter2gw.jpg
    Both apparently have gold connectors, whether that makes a difference or not I dont know.
    Get more info in this thread: http://www.hdtvarcade.com/hdtvforum/viewtopic.php?t=2085&sid=fad20ae918dcebcbc9a67d9f01bc4c67
    So which gives a better picture, component or VGA?
  6. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I'm inclined to say VGA might have the slight edge because it wouldn't have the 4:2:2 (I think?) compressed colour space?
  7. Mad Jack
    Mad Jack
    Oct 7, 2004
    453
    +40
    I saw the MS E3 press conference the other day and they said they'd instructed/requested that developers make all their Xbox 360 games support a default 16:9 aspect ratio and resolutions of at least 720p/1080i. They added that the games would still look great if they were displayed on 4:3 SD TVs.
  8. Henders
    Henders
    May 6, 2003
    79
    Sorry for the stupid question, but does the VGA cable enable you to use the xbox with a computer monitor? If so, will it be able to output 720i/p to the monitor?
  9. serial45
    serial45
    May 20, 2005
    248
    Liverpool UK
    +17
    w00t! thanks for the info mate!
  10. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Yeah, that's what the VGA cable's for, and it will output 720p.
    (No such thing as 720i though).
  11. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I would expect this to be OK for games, but if you want to play pre recorded media, expect HDCP to be mandatory for HD output.
    -Ian
  12. singaporta
    singaporta
    I've also dubts. Ps3 will have HDMI, which if I'm not wrong carry on also sound signal. My Sharp have only DVI so I will buy an adaptor but what about the audio signal?Consider I dont' have an home theater for digital audio signal. Is there an adaptor HDMI to DVI+rca audio?
  13. SIDEARM
    SIDEARM
    Yes dont worry you shouldnt have any trouble finding an adaptor. In fact I would be suprised if sony dont have their own adaptor solution to this problem as vast numbers of people have DVI equipped tvs (far more than have HDMI im sure)
  14. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    The PS3 has 2 HDMI sockets and the same multi AV socket the PS1 and PS2 had. You do not have to own an HDMI equipped display to use it. :rolleyes:
  15. singaporta
    singaporta
    Yes I know I can use the actual component cable but if I want to have 720p or 1080i with digital signal and not analog like component one, I need to use the HDMI socket and a to DVI adapter
  16. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    HDMI is digital audio, so its not a simple breakout cable for RCA analogue audio, you would need to do a D/A conversion. However, I would expect it to have its own audio analogue outs, probably in a similar fashion to the PS2 via the proprietry connector - which would probably carry analogue video too. It may also have a separate digital audio out too,like to optical connector.
    -Ian
  17. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    The PS3 will contain a similar AV out than the PS2 has at the moment, so it should also be able to output HD via component.
  18. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Except for much pre recorded content...
